Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1526 Questions View all
iPhone 6 Plus sporadically turns off <60% charge, bad battery?
Good afternoon,
I have purchased an iPhone 6 plus on eBay from a reputable seller. The phone was not 100% new but I was advised it was a stock model and in good condition. When I received the phone (without retail packaging) I had no indication to think otherwise, it did not even have a scratch on it.
I've had the phone for about 2 months and a strange issue began to surface. For some reason, when the phone's battery is below 60% and I use it outside to take a picture or watch a youtube video, it completely turns off. The phone will not turn back on unless I plug it into a wall charger. It does not have to plugged in for long, even for ~5 seconds is enough. It's almost like a car with a dead battery that needs another car to help it jump-start.
When the phone turns back on it shows the same battery level as when it died, i.e. is not at 5%. I should also add that this does not happen every single time, but I would say it happens over 50% of the time, which is obviously too much too tolerate.
I read through similar iFixit forum posts about battery issues, so here's my question: does it sound like an old battery issue or a damaged tristar ic (or something else?). The phone came with a brand new and, from what I can tell, genuine Apple charger, although I cannot vouch if a non-apple charger has been used with this phone in the past.
Add a comment
Chosen Solution
Most likely battery just needs to be replaced. Try that first because it is the cheapest option.
Score 3
1 Comment:
Thank you for your reply. Probably a rhetoric question but... The iPhone 6 plus batteries sold on this website are authentic batteries?
by
Add a comment
Hi there ll be 2 issues
1. Try with changing New Battery
U can Go Through The Link For Genuine Battery
iPhone 6 Plus Battery
2.There ll be issue with U2IC Issue on Board Level or Restore the Device
Hope it Works
Thanks
Varun
iPhone 6 Plus Battery Image
Product
$29.99
Add a comment
Add your answer
Jason M will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 3
All Time: 259
