Repair guides and support for your LG TV.
1340 Questions View all
model 42LE5510-Only shows LG logo, no picture,sound, menu doesn't work
TV stopped working. Now only shows the LG logo with the time. Cannot change screen with remote or by using the buttons on TV. Nothing has been changed to cause issues.
2 Comments
Did you purchase it within the last year? The last three years?
by
No, purchased 2010
by
Add a comment
1 Answer
Chosen Solution
Hi,
Getting the logo on the screen is actually a positive sign.
It proves that the screen is working, and also that the power is probably OK as well. It also proves that the firmware is partially working.
If possible try re-installing the firmware into the TV and see if this solves the problem. It may not work as sometimes you cannot install the same version only an updated version.
Here is a link to the support page for your TV. Scroll down to Software and Firmware to find the two files necessary. The guide will tell you how to install the firmware and the firmware itself. Note that it is a .zip file and will have to be uncompressed but most PCs do that automatically these days. Also even though it might say so, make sure that you load the firmware into the root directory of the USB drive that you plug into the TV. Do not put it into a folder as it won't be found.
Follow the directions and be patient as it might take a little while to complete. I cannot say how long as it varies between brands, but generally it is not long.
http://www.lg.com/au/support/support-pro...
Hopefully this is of some help.
Score 1
2 Comments:
Thanks, I was really hopeful, but after doing as you suggested the TV still only displays LG logo. Couldn't get any other screen to show for the setup
by
Hi,
Not your model but an LG all the same. This link may be of interest. At this stage you've not much to lose, although baking the mainboard may be stretching that a bit.
http://www.badcaps.net/forum/showthread....
by
Add a comment
Add your answer
cccbeer will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 2,376
