5 speed transmission won't go into gear. Sometimes it changes fine
How to bleed hydraulic slave cylinder
@wood1960 ,David, The links below will tell/show how to bleed the hydraulic clutch system in your Toyota truck. Best to have an assistant to help and a few rags, actually the links below will tell you what you will all need. Good luck.
http://www.ehow.com/how_7852304_bleed-hy...
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 42
