iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
397 Questions View all
Can I upgrade the logic board of an iMac (late 2009) to a later model?
I was wondering if I could upgrade the logicboard of an iMac 2009 to, say 2011.
The reason has to do with paying a lot of import taxes in Brazil if I buy the whole computer.
Add a comment
Spread Fixmas Cheer
Get $12 off your purchase of $50 or more with code FIXMAS12
Spread Fixmas Cheer
1 Answer
Chosen Solution
Sadly Apple made large changes between the series as such you won't be able to swap out your logic board.
There are a few things you can do to improve performance like upping the RAM (8 GB or 10 GB)
Upgrading the HD or better yet setup a dual drive using a SSD drive.
Here's the IFIXIT guide and part you'll need for a dual drive config: Installing iMac Intel 27" EMC 2309 and 2374 Dual Hard Drive. I would recommend a 128 GB or 256 GB SSD here. You'll need to be careful on what SSD you go with as your system only has a 3.0 Gb/s SATA port. So you'll need a drive that supports this slower speed.
Score 1
Add a comment
Add your answer
Renan de Araujo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 17
All Time: 273
