The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1529 Questions View all
Using the iSlack doesn't pry up the digitizer with it
I want to replace my dumb iPhone 5c's battery. I pry up the screen using the iSclack, but only the screen comes up with it, and not the digitizer. It seems like Apple didn't glue the digitizer properly, since my phone is a little pried up from the top ever since I bought it.
What can I do to remove the digitizer along with the screen?
Score 1
Comments:
Did you remove the screws from the bottom of the case as mentioned below It wont come out if you dont
by
Add a comment
Chosen Solution
The 5C doesn't have a home button cable, attached to the Lightning dock. Honestly I never use a suction cup anymore. The spudger is a good tool, or you can use a flat head screw driver. Make sure to pry from the bottom right, so as not to disturb the two gold pins, on the Lightning dock
Score 4
Add a comment
You Probably Have Screen Separation Witch Is Screen Defect Or User Error It Should Come Off As One Just Be Carful Not To Rip Home Button Cable
Comments:
You Kinda Just Got To Play Around With It Do You Have Picture Of It
by
Spudger
Good Tool For Getting Screen And LCD Off
by
I'll edit my question
by
I edited my question with the image
by
Did You Take Out The Penelope Screws At The Bottom By The Charging Port?
by
Show 3 more comments
Add a comment
Add your answer
Developer Ali will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 4
All Time: 86
