Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
I can't hear but I can be heard when making a phone call after new sc
I recently did a phone lcd screeen replacement and after i finished i ran my test and i couldn't hear the other party on the line... i can hear them but they can't hear me... the only way to hear them is if you put it on speaker. Pleae help
Update (01/18/2017)
Also i cant take pictures with the front facing camera
Update (01/21/2017)
Is there a guide on how to install this??? Because i've tried repositioning it several times and to no avail
Score 1
1 Comment
This may sound silly but did you make sure to remove the protective plastic screen sheet that came on the part. Often times it blocks the speaker
by
Add a comment
Most Helpful Answer
The Front-facing camera and earpiece speaker are on the same cable so make sure the cable is properly seated. If it still doesn't work, try to get a new earpiece and camera assembly.
Score 4
6 Comments:
Do you know the cause of this
by
Maybe i can prevent it in the future
by
It may just be because you just didn't seat it correctly, or it could just
be its a defective part.
by
Maybe you could post a guide, or a link to parts @gigabit87898
by
Is there a guide on how to install it?
by
Show 1 more comment
Add a comment
It's possible you could have torn or damaged the front camera flex cable, assuming you did transfer and install the cable properly. If the cable is damaged you can buy a new one for about $4
http://www.ebay.com/itm/OEM-Front-Face-C...
Score 1
Add a comment
Check no.1 the seating on the screen connections.
Check no.2 Have you transferred old ear speaker from old screen? It it sitting flush with the two guides from front camera?
Worth taking ear speaker out and reseating
Add a comment
Add your answer
Nick Genco will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 111
