Gun quit firing. I changed the batteries but to no avail. Help!
My grandson got the Nerf Mega Mastodon for his birthday today. It stopped shooting and making any noise about an hour after he opened it. We have replaced the batteries with brand new ones again but it still does not work. Do you have any suggestions?
Score 3
1 Comment
have same problem got it and then it stopped firing after 1 day of use
by
Add a comment
Most Helpful Answer
open the jam door. Even if it’s not jammed, open and close this. It will start working again
Score 3
2 Comments:
Anne Hollenberg Where Is The Jam Door?
by
A little grey flap on the top left side where the drum is.
by
Add a comment
Jam door switch is usually the culprit. Open the case by undoing the 19 or 20 odd screws, remove the jam door, wiggle the little black rubber coated switch. Put it back together without the jam door so you can access the switch if it happens again.
Add a comment
Add your answer
suzanne4785 will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 36
All Time: 3,402
