Why does the room digital heater loses it's set temperature
Set at 78-later see it set at 69?
@anncarjor the display may show you the room temperature, not the set temperature. Once you set the temp, the display will flash for five seconds, become constant for five seconds and then returns to display room temperature. You can check this with a separate thermostat and see what the true temp is. You do want to make sure that you do not have the timer set for anything else.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 213
