Released June 2009 / 2.53 GHz Core 2 Duo Processor
170 Questions View all
I replaced the keyboard and now my MacBook Pro 15" won't power up.
I had several keys not working, so i replaced the keyboard...seemingly without fail.
But now the plug attached to the body lights up orange, then green.....but pushing the power button gets nothing.
2 Comments
Can you give us the exact model you have. If you can still see the serial number on your bottom cover you can find your system here: EveryMac - Lookup. Once you know paste the systems URL link here for us to see.
by
Add a comment
Most Helpful Answer
Did you test the keyboard before fitting? Have you rechecked the connection, to make sure it is all the way inside the connector, and the flap is down? Could be a faulty keyboard if you did not check this beforehand.
If none of the above, you have either damaged the keyboard whilst fitting, or damaged the board (assuming you have checked all connectors).
Score 1
Add a comment
The system you have is a bit of an odd duck ;-} Apple had two variations in the Mid 2009 15" models. This one is the 2.53 GHz unit which used a different body. To add to this the Upper case also has two variations:
  • Top Case w/Keyboard, Glossy 661-5244
  • Top Case w/Keyboard, Anti-Glare 661-5297
So you do need to get the correct one. I have never found a workable keyboard sub assembly for this series so if you got one make sure its for this system I suspect you got the wrong one (you'll need to get the uppercase).
OK how to isolate this down? I would disconnect the keyboard ribbon cable and connect the MagSafe adapter to the system, then use the power pads to see if I could start up the system. Use a screw driver to short across these two pads:
Did the system start up?
If it did you have the wrong keyboard, if not you need to figure out whats still wrong with the system.
Score 1
1 Comment:
Thankyou very much. I'm going to get started soon as im home from work. Will let you know, i appreciate your help tremendously!!
by
Add a comment
Add your answer
mantgriller will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 72
