Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Questions View all
Can't turn it on anymore
Hi there,
I have an Mid2014 Retina and used it very often like 8-12 hours a day.
A few weeks ago I got the message to change the battery.
In my holiday (from EU to Mexico) my macBook worked for about two days and after that I can't power it up anymore.
I replaced the battery yesterday.
The MagSafe was showing a Orange light and today it's green. So I think the battery is fully charged. But I can't still turn it on!
What options do I have to get the MacBook running again?
I am not sure if this is a problem but the first chip on the SSD is getting a little bit hot when charging.
Add a comment
I would open it up, and disconnect the battery and SSD and try to boot the laptop. The computer should boot, and show a blinking question mark folder. If this doesn't work, then there is very likely something wrong with the logic board and something will need to be fixed on there.
2 Comments:
I tried this. But nothing happen. So there would be a problem with the logic board. The best option would be to buy a new logic board right? I don't think that this logic board is repairable.
by
Welllll, technically almost any issue with a logic board is repairable, but it requires that you have a multimeter and soldering equipment. If you'd like to save some money, there are many stores that do component-level motherboard repair.
by
Add a comment
You might need to do a SMC reset. It's worked for me in the passed when ive replaced batteries.
http://support.apple.com/kb/ht3964
Add a comment
Add your answer
tais46 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 76
