My phone don't connect to 3g network
my blu studio 6.0hd.d650a, don't connect to 3g service if I switch to 3g. but instead It show error signal in my network bar, and then switch itself back to 2g service. it so frustrating not able to browse with 3g service. I have tried all method I know like checking my network setting but still not working.. please I help
Score 2
4 Comments
I tried with different handset it doesn’t work
by
I tried different sim but don’t work
by
Hi could you help me please
by
What of a phone that was bought in the US and shipped to Nigeria. How do we do that? Could not connect to 3G
by
Add a comment
1 Answer
Chosen Solution
Hi,
Try another known 3G working, network compatible SIM card in your phone and see if it works.
Try your SIM card in a known 3G working, network compatible phone and see if it works there.
Basically swap the SIM cards between two same network phones and see if the problem stays with your phone or moves to the other phone.
If the problem (no 3G signal) moves to the other phone you have a faulty SIM card. Contact your service provider about a SIM card replacement.
If the problem remains with your phone then there is a problem with your phone.
If the problem is in your phone, backup the phone, using the phone's backup feature and perform a factory reset, using the phone's factory reset (or factory restore) feature. Once the reset is complete see if the phone now works with 3G.
If it doesn't then there is a hardware fault with the phone. How long have you had the phone? There is a 12 month manufacturer's warranty on the phone. If you have had the phone from "new" for less than 12 months, verify the purchase date and then consult the warranty statement in the documentation that came with the phone as to what you have to do to make a claim for a warranty repair or replacement. If you cannot find the documentation here is a link to the warranty provisions for the USA http://bluproducts.com/images/US_Limited...
If it does restore the phone using the backup you made earlier and then make sure that the 3G still works.
Score 5
Add a comment
Add your answer
Irowa Ede will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 13
All Time: 20,407
