iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
904 Questions View all
iPod Classic: Erratic lock switch - before & after replacement
iPod Classic 160G
Initial problems:
Lock / hold switch worked intermittently - in the unlocked position the lock icon blinked on & off. If you could select functions in between blinking the iPod worked fine.
Would not hold charge - charge icon would rarely come on but it would indicate a full battery after several hours of charging.
Repair:
Replaced battery and lock switch / earphone jack
Restored via iTunes - multiple times
Reformatted drive in disk utility - multiple times
It will accept playlist and function normally when it's not freaking out which is 98% of the time ...
New & continuing problems
Lock switch still intermittent- blinking icon
Won't stay asleep (press and hold pause) wakes up 30 sec. later
Won't wake up unless plugged in then you realize lock icon is on or blinking rapidly .... lock switch position is irrelevant.
Pretty lost .... is my new switch defective or am I looking at a logic board or hard drive issue?
Any suggestions welcome
Phil
Update (01/10/2017)
Thanks Tony,
Sounds like a good fix, I'm assuming Apple won't do this so I'd have to find a independent electronics guy. Is the diode easy to locate? I'm down here in the tropics and not to confident about local diagnostic skills. Not to mention the boards pretty small! Any pointers would be really appreciated.
Crash
1 Comment
phil no schematics are available for the iPod range that i am aware of. the tech will have to trace the line from the button the diode will be 6.8V-100PF more than likely a 1005 ferrite package . good luck
by
Add a comment
1 Answer
Most Helpful Answer
Phil the issue is caused by a defective diode on the logic board. all buttons on all devices function when you press a button the diode goes to ground and pulls a signal from the CPU creating a command. a local repairer will be able to replace the diode for you
Score 1
Add a comment
Add your answer
Crashbuilder will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 378
