Repair information and guides for MacBook Pro models with 13" displays.
9756 Questions View all
Buzzing sound from system during boot up & when playing music & vids
I'm hearing a buzzing sound while starting the system as well as while playing movies and listening music. But, the buzzing sounds go away if I use headphones.
Is there any way to fix the buzzing sound?
2 Comments
Did you get your system wet at some point? Sounds like you have some corrosion damage.
by
for that I can say is I did used a keyboard cover for last 3 years...and I did find some times that the cover little bit wet...
by
Add a comment
1 Answer
Chosen Solution
Then it does sound like you have corrosion damage.
You'll need to open the system up quite far to look for all of the damage.
It might make sense to let a Pro do this than your self. At least it sounds like the keyboard will need to be replaced which by its self is a big job for most.
Add a comment
Add your answer
Ahmed will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 37
