Belt won't run after I replaced broken one
Older 1981 2 stage Toro snowblower. Belt snapped so I replaced it. The handle for auger to run is very loose but I see the tensioner move when I depress handle. Why won't belt run?
Score 1
1 Comment
LPfaff, was the belt configuration. Once I found that,got the right belt, it was up and running. Just in time to clear 10" snow, thanks again!
by
Add a comment
1 Answer
Chosen Solution
@luugar , Joel, If you are sure belt is routed properly, you may have installed a belt that is too large,especially if you are noticing the engagement lever looser then what it was prior. Recheck the belt for correct replacement. If belt is indeed correct you may have to adjust the drive cable or tensioner pulley. You can verify using the 1st link below to see if you have correct belt. Other links are a service manual and Toro where you can request a manual if needed. Good luck.
http://www.jackssmallengines.com/manufac...
http://shryp.ashendust.com/Snowblowers/2...
https://lookup3.toro.com/request/request...
Score 2
2 Comments:
Thanks for the manual and the links. I will check those and hopefully get it running.
by
Joel, I am sure you will get it. thanks for posting back. good luck.
by
Add a comment
Add your answer
Joel will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 73
