Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1169 Questions View all
Replaced headphone jack; now iPhone won't turn on.
I went through the ifixit procedure to replace the headphone jack ribbon cable assembly. Installed a new battery while I was at it. Everything went perfectly, according to the instructions and photos. I figured I should charge the battery after buttoning it up, so before trying to turn on the phone I plugged in the power. Battery indicator immediately came on in the red zone. Then this was replaced by the Apple logo, so I figured the iPhone was rebooting. Then, the logo gradually faded out to nothing; this took about 30 seconds. I left it charging for about an hour. Now nothing happens, except when I plug the iPhone into power and hit the wake/sleep button, sometimes the Apple logo appears bright for a few seconds, then dims, then gradually fades to black. Once that happens, no matter what buttons I push, including trying a hard reset, nothing happens – screen stays black. Help!
Score -1
Add a comment
Chosen Solution
your battery is probably not connected right. check the contacts are clean, prongs aren't flattened and that the screws near don't remove sticker are in right (one of the screw is slightly longer than others to give a tight fit) then check dock connector (connector 4) is on right too and free from dirt. if none of the above work, reinstall the old battery. if that works you have a bad battery so return it.
Add a comment
You are absolutely correct. I reinstalled the old battery and the iPhone works like a charm. Muchas gracias!
1 Comment:
glad it worked!
by
Add a comment
Add your answer
johnamcmahon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 714
