Why won't my Nespresso Pixie power on?
My 3 year old Nespresso Pixie (Chrome) will not power on (green lights will not show up) at all after pushing the button to do so. Was working fine until I didn't use it for a few months. I've taken the thing apart in the hopes that I could find something obviously wrong (corroded terminal, blown fuse, etc), but could't really find much.
Tried to hold down the espresso and lungo buttons for 20 secs to see if that did anything, but it didn't.
Anyone had this problem before or any suggestions?
Thanks!
-C
Add a comment
Chosen Solution
Cole Claiborne since it sounds like your Nespresso is not doing much of anything, start with the basic trouble shooting. Since you already have it apart, post plenty of pictures with your question. That way we can see what you see. For that use this guide
4.1 Coffee machine is not working (does not function)
a) YES - power cord is okay (loose connection)
YES - continue
NO - replace power cord
b) YES - On/Off switch has typical switching noise
YES - continue
NO - replace functional block
c) YES - pump works (press a coffee button)
YES - continue with point e)
NO - continue with point d)
d) YES - both coffee buttons are working
YES - replace pump
e) YES - fine wire fuses or triac on thermoblock defective
YES - replace thermoblock
NO - continue
f) YES - wiring is okay
NO - continue with point 4.2
YES - replace functional block
NO - replace defective cables
Let us know what you find with each point.
Score 1
1 Comment:
My Power Switch is not working, where can we find parts for these Nespresso Type C60 machines. I need to replace the block. Thanks
by
Add a comment
The instructions are ridiculous.
Add a comment
Add your answer
Cole Claiborne will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 48
Past 30 Days: 151
All Time: 45,583
