The Sony Xperia Z is an Android based phone that was released in 2013. It is one of the largest phones of the Xperia family with a 5-inch full HD display. Model numbers include C6603/C6602.
98 Questions View all
Help Broken Charger Port!
When my phone was finished chargong the other day, I pulled the usb cable out and the flat pin from inside the charger port came away with the cable.
Is it quite easy to replace the port? I have done this with other android phones but never with an xperia
thanks
Add a comment
1 Answer
Hi Janie,
If you have replaced the charge port on another phone, you should be okay. I would recommend a good quality low melt solder paste as this will make the removal of the shielding easier. (Just remember to remove all the low melt solder before soldering the new charge port on or you will have connection issues)
Hope this helps
Add a comment
Add your answer
Janie Campbell will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 639
