Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 Questions View all
Won't reboot and got error code 4SNS/1/C0000008: Ts0P--124
MacBook Pro 8 2 2011
I was working on my quickbooks when my screen went completely red.
I manually turned off my computer and turned it back on. The working line was red and never loaded.
I shut it down again and ran an error test. I got this error code: 4SNS/1/C0000008: Ts0P--124
So I manually shut down again and tried to start it in safe mode. It acted like it would reboot but then went to a white screen. My computer will not get past the login screen. What do I need to do?
Score 1
Add a comment
Chosen Solution
First you have a bad thermal sensor which is what the error is: TsOP = Palmrest Proximity sensor.
Often when I see this the system has gotten something spilled into the keyboard and/or trackpad which has corroded the connections. The sensor is part of the Trackpad assembly. Here is the IFIXIT guide: MacBook Pro 15" Unibody Early 2011 Trackpad Replacement.
You should also make a full inspection of the system for any other corrosion damage and also clean out any dust in the fan's and fins.
Score 2
Add a comment
I had this error. Put "defective"trackpad into a new machine. Error gone. Searched the web and people said the webcam cable could also be to blame. Disconnected webcam cable. All issues stopped.
Score 1
Add a comment
Add your answer
amydoodledoll will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 418
