Repair information and guides for the iPhone 6S released by Apple on September 25, 2015. Models: A1688, A1633
2692 Questions View all
Why won't the iPhone's screen stay on?
Hello,
My buddy recently tried to replace his iPhone 6S screen. He followed the directions and managed to get everything switched over. However, when he turns the phone on, the lock screen will come up for a split second and then turn off again.
He gave it to me, and I checked to make sure the cables were connected properly. I also discharged the battery. That did not help, so I attempted to reinstall the old screen. Both screens are doing the same thing now.
I did notice something odd. After the battery has been discharged, when connected to a charger the charging icon will come up and stay visible. When it has been charged sufficiently, the phone will boot up and the lock screen will show for a split second and then turn black. It sounds like you can still interact with it. Truthfully, I'm baffled. I have no idea what the issue is.
Score 1
3 Comments
does the screen stay on in recovery mode?
by
I've noticed this happening with the new S model phones. It's very annoying, and I don't know why it's happening, which is even more annoying
by
Thanks for your responses.
Either my timing is off, or recovery mode doesn't help. I can't really tell when it turns off or back on, so I tried doing it from memory.
I tried to hook it up to a computer, and iTunes said there was an issue with the phone and that it needed to be updated. It then asks me to respond on the phone to authorize access, but I can't do so for obvious reasons.
by
Add a comment
1 Answer
Chosen Solution
I would try to connect just the digitizer and LCD and not connect the front camera connector. (see this step in the guide). If that doesn't work, then try hard reset (presse the home & power button for 10 secs).
You could always try a DFU Mode but that would delete your data.
Score 1
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 199
