MacBook Pro models with a 15" display
8257 Questions View all
ALT (Option) Dosen't work for Anything Command at start
i will use startup manager for booting with usb device but ALT ( Option) doesn't work at starting up, i search solve in google i find to reset NVRAM with "CMD + Option +P+R" This command doesn't work too because ALT ( Option) not working for any Command have this button
ALT (Option) Work in OS but at starting up not working please help me!!
I disable SIP and i Enable it and no result.
Score 1
Add a comment
1 Answer
Chosen Solution
Are you holding alt 100% of the time before and after pressing the power button until the boot selection menu displays?
It may take around 10-30 secs while holding alt.
Depending on which OS was installed some may take longer to show it when trying to get to the EFI boot menu.
Score 2
1 Comment:
Yes Sir i holding ALT 100% and i holder it before and after and sam result..
i think ALT button has Disabled on my mac at startup because all Command with ALT doesn't Work (Shift+Control+ALT, CMD + ALT + P+R...) all this command not working because have button ALT.
if i holding ALT 30 secs or what ever MacBook login to OS Sierra like i doesn't hod it..
i Try Reset PRAM from Terminal no result..
this problem happened after i disabled (SIP) last month i activated again and nothing
if you have solution please to flash or reset all setting to default please tell me how
by
Add a comment
Add your answer
Ayoub will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 2
All Time: 191
