Gateway makes quality notebooks, laptops, and netbooks. Owned by Acer Group.
220 Questions View all
Dropped my laptop now won't boot!
I dropped my lap top onto a cement porch and now it won't boot up I think something came loose inside. Is it OK to open it could I see if something is loose? I use to solder circut boards for a living so I could make that repair my self,! Any suggestions on fixing it my self?
Score 3
1 Comment
We will need some additional info here. Does the laptop simply not boot to an operating system, or does it not show anything on the screen anymore? What model number? Can you remove and replace the battery? Have you tried powering it on while plugging it in vs. just on battery power?
by
Add a comment
Chosen Solution
@gateway , As Michael stated more info, laptop model #, etc. would help. What you could do is google search for a tear down on your device, which would show how to take it apart and then you could look/verify whether components are loose/broken, reseat the ram, check all connections, etc.. Good luck.
Score 3
Add a comment
I would think if something is loose? It would be, harddrive,memory(ram),fan,bios battery and such? It wouldnt hurt to take a quick look, but just be careful and dont break it more? Do it, do and learn is what I say, unless its a customer, or your job, haha :)
And i am sorry to hear about your accident! Hope it ends well till the end :)
Score 1
Add a comment
Did the same thing with Gateway laptop NE56R48u. Left it off for 3 days. Tried to power up while plugged into outlet. Nothing after several hours and trying several key combinations to restart, etc. Nothing. Shut down, unplugged, waited a few hours. Put on rubber soled shoes and opened up back hoping to find something loose, took out battery, then reseated. Still no luck.
After a few days, tried it again and nothing happened for awhile. Then Boot Manager popped up. Screen said:
Boot. Option. Menu
“Up arrow” and “down arrow” to change option.
ENTER to select an option
Then the rest of the screen is blank...no options to choose.
Nothing on keyboard seems to work.
1 Comment:
im having the exact same issue did u ever figure it out
by
Add a comment
Add your answer
Leslie McClelland will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 49
All Time: 14,602
