Battery indicator has an X, and charger light stays green,
My battery indicator at the top of the screen has an X inside it, and the side indicator when I press the button doesn't light up to show how much battery is left. When I plug my charger in the light goes straight to green, I can't tell if its charging or not because of the X in the indicator. I turned my laptop off and on again and its still the same. Also it sounds like the fan over-heater things (i'm so not tech savvy so bare with me lol) are going off loudly, (sounds like a hair dryer just not as loud) yet my laptop isn't hot at all. I've closed all applications and tabs so really, my laptop shouldn't be over-worked as it should't be doing anything.
Hope someone can help!
Comments:
I should also mention its still on atm, it hasn't ran out of battery or not turning on.
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
Try an SMC reset, more information on how to do it here:
https://support.apple.com/en-au/HT201295
The key combination is to hold Ctrl + Shift + Option when turning on the MacBook. You only need to press and hold the power button for 5 seconds when doing that.
If that does not fix the problem then you may be looking at possible liquid damage on the board causing this.
Score 2
Comments:
thank you so much, that seems to have done the trick!
by
Add a comment
Add your answer
princesstye will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 62
