Dc charging port broken. Won't charge
Need to replace female dc charging port.
Hello, I had the same issue with mine, and after scouring the internet I found the CORRECT replacement DJ jack part via an Aliexpress seller. I had to order 4 different jacks, 2 different times, but finally the 6 month search ended with the right part.
https://www.aliexpress.com/item/For-Sony...
In case that seller link dies, you can source out your own by searching “Sony DC power jack” and the part/model number is “DC-022”. Good Luck!
Great!!!!! Thanks :) :)
Im planing to solder another type of female and male connectors direct to board but still use my DC charger.
I got the DC Power Port/Jack on Alibaba.
It's a Sony, and it's black in color.
Here is the part description and number:
DC POWER JACK CHARGING SOCKET PLUG PORT FOR SONY VAIO PCG-8L3L PCG-8L4L PCG-8L5L PCG-954A
The store front name on Alibaba is: "Glcome Store"
Hope that helps someone!
Axle
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 15
All Time: 964
5 Comments
Thank you so much for your question, I have the exact problem and no idea how to start nor even get the part, I hope someone has an answer. I would be so great full. Thanks again and if I do find one I'll let you know, this is a great little speaker
Regards luckystyx
by Lucky Styx
I am sorry to bother you, I am an old newbie, but if you do find an answer for the issue you have it would be great to be able to fix mine as a well, thank you in advance Regards. T
by Lucky Styx
Thank you Kevin Madden, I ordered the exact DC in Power Port that you suggested but the OD of the yellow port was too small for the OD of the Sony AC Power Adapter male jack. By chance do you know the Manufacturer and Part Number of the port that worked for you Sir?
thank you very much
Alex
by Axle Rod
Looks like a Fujitsu part, does anyone know how to look up yellow Fujitsu DC Power Ports (i.e. Jacks)? thank you
by Axle Rod
On the 3rd try I did get the right DC Power Port on Alibaba. It's a Sony, and it's black in color.
by Axle Rod
