Two-wheeled, motor-driven transportation, including mopeds and scooters.
565 Questions View all
engine backfires at varying speeds, especially when deceleration
1998 royal star motorcycle
When at cruising speeds and when slowing down in deceleration the engine backfires. Have checked all fittings to ensure tight and replaced gaskets. Adjusted carbs to try different fuel air mixtures.
1 Comment
I have found out that in a multi-carb system, the carburetors need to be synchronized. That eliminated the backfiring.
by
Add a comment
Chosen Solution
ironmonkeyto, Make sure carbs are adjusted correctly and fuel levels are good, one of the biggest reasons for this is if you have an exhaust leak. Check for leaks at all exhaust connections especially at exhaust port/engine connection as well as any cracks/breaks in exhaust system. Good luck.
Score 2
Add a comment
timing and valve adjustment can be the issue also
Score 1
Add a comment
Add your answer
ironmonkeyto will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 68
