Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
How do I trigger the Home button without the front assembly?
I have an iPhone 3GS that was dropped, The entire front panel assembly (glass, LCD, home button) is broken.
I want to see if I can restart it, but for that to happen, I need to somehow close the Home button circuit to emulate the button.
I've tried connecting the two fields that would have hit the button prongs, but I'm not having any luck.
Score -1
1 Comment
what is it you want to do with phone when it's on?
by
Add a comment
1 Answer
Chosen Solution
You guessed right. To emulate the home button being pressed you need to short the two exposed pads. I like using a pair of metal tweezers, but you can use a paper clip bent into a "U" shape.
EDIT: Click the image for a larger resolution. Sorry about the rotation.
Score 1
Add a comment
Add your answer
Christopher M will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 6
All Time: 1,331
