The Toshiba Satellite C55-C5268 is a general use laptop designed to be used with windows 10. It was manufactured by Toshiba in 2015.
10 Questions View all
Why won't my mouse buttons work?
The two mouse buttons on my laptop aren't jammed but when I click on something it doesn't respond. The touch pad above the mouse works fine and I can click on things with that but the mouse buttons still don't work. What is causing this problem and how can I solve it?
Score 1
Add a comment
1 Answer
Most Helpful Answer
There are a couple of reasons you might be having this problem.
First, make sure your laptop does not have a "disable mouse button" command. This feature can usually be turned on and off by pressing Fn+(F1,F2,F3, etc). If you still have the user manual you can check that for the specific command.
Another reason is a bit more intensive to check. The ribbon cable connecting the touchpad buttons to the motherboard might be disconnected, which would require you to remove the bottom cover of the laptop to reinsert. Removing the bottom plate is fairly easy, just follow the guide here. The cable you'd be looking for would be coming out of the back of the touchpad and leading to the motherboard.
The buttons themselves could also be faulty. This could happen over time through use, or if something got spilled on them. In this case your best option would be to replace or clean them.
Score 1
Add a comment
Add your answer
Ben Rounseville will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 33
All Time: 546
