Why isn't my Polaroid working properly?
my instax film is coming out blank as well it is brand new film. i took a picture in my car then on the beach I wanted to take a picture but it turned out white. On the back where you place the film it has a S and it goes to S and goes to 10. I was wondering what that ment? or how i can fix this problem please.
Add a comment
1 Answer
Firstly,
The numbers on the back are the amount of film you have left in the canister. It resets every time you change the film.
Secondly,
Make sure that your exposure settings are correct, the camera will detect which is the best setting by lighting the orange LED on the right setting. You will then have to rotate the lens manually to that setting for the picture to be the best quality.
Also make sure your fingers aren't covering the two black sensors above the lens, this can cause the camera to take over exposed shots, making them white.
I hope this helps.
Add a comment
Add your answer
Victoria Sanchez will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 128
