2.26 or 2.4 GHz / White plastic unibody enclosure
645 Questions View all
Replaced logic board, no boot, just fan spinning and sleep light on
So my trusty A1342 had one of its RAM slots die unexpectedly, and I ordered a refurbished logic board online.
It originally came with the 2.26Ghz board and I went for the 2.4Ghz, just to eke out a little bit more performance out of it.
However, while the replacement board seems to be in top shape (nothing bent/broken, all connectors are snug etc), after installing it into my Macbook it appears to be dead.
The magsafe light indicates charging. Pressing the power button spins up the fan, and the sleep light turns on, but that's it - no beeps, no error codes, no light flashing, no DVD spin up noise.
It just stands there, spinning its fans. Removing the RAM is the same (no beeps), so I'm guessing the board is fried, right?
Is there else I should have swapped when switching logic boards? Does a move from the 2.26ghz board to the 2.4ghz pose problems?
Thanks in advance
1 Comment
Kind of sounds like a dead firmware chip...
by
Add a comment
1 Answer
Chosen Solution
A change in the logic board shouldn't cause any problems, so there is probably an issue with the new motherboard that you bought. Where did you buy it from? I would try to get a refund as it definitely seems like the motherboard is defective.
Score 2
Add a comment
Add your answer
Themistocles Chalikias will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 7
All Time: 65
