2.0GHz, 2.3GHz, or 2.6GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.8GHz) with 6MB shared L3 cache.
580 Questions View all
Loose CPU heatsink on MBPr 15" (pictures inside)
Hello, I have swapped my mbpr ssd and opened it for the 1st time...
I have noticed that one of the sockets on the motherboard where the heatsink screws are, is out of its place. The other 3 screws seems fine. You can see that in the image (sorry for the dust, will clean it before closing it back :))
Before doing anything, what do you recommend? is there any special glue for motherboards???
thank you!
picture: http://forums.macrumors.com/attachments/...
Score 1
Add a comment
Chosen Solution
Well I've seen some failures but this is a new one for me!
So you have a few options here, take the system in to an Apple store to see what they say. It should be covered under warranty as it's clearly a manufauring defect. Will they cover it, I don't know. But I would try that first.
As to refitting the stud back onto the logic board, it will take some effort as you'll need to remove the logic board place the board on a block so only the area under the stud is supported as you don't want to damage any of the small components on the backside of the PCB.
You'll need some Cyanoacrylate glue (Super Glue) carefully wet the logic board wall and press the stud back in. I would recommend using a stud press and slowly press it back in.
Speed is your enemy here as pressing too fast will cause the laminates to spit apart.
Good Luck!
Score 2
Add a comment
There is no stud. That crap is just glued onto the board. The problem is the way Apple designed it - the “wings” on the heatsink act as springs and they apply a pull-up pressure on those stands constantly, eventually rip them off the board. You can use super glue to re-attach it, but bend the wing down slightly until there is no gap between the hole and the stand like it was before to eliminate that pull-up pressure. As long as all four screws are tightened down, the heatsink would make perfect contact. I just did mine.
Score 1
Add a comment
Tried your method, hoping for the best
Add a comment
Add your answer
david will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 5
All Time: 403
