Why won't my Stream 7 power on?
Why won't my HP Stream 7 power on? I have tried every charger I have, and tried plugging it into my PC via USB. I've tried doing a hard reset by holding down the volume-down and power buttons for extended periods. Completely unresponsive.
2 Comments
Hi, Just clarifying. Did you press and hold the Volume Down button 'before' you pressed and held the Power button then with both buttons held when the startup menu appears release the Volume down button?
by jayeff
Thanks for responding, jayeff. To answer your question, I think I had tried every combination of Volume Up/Volume Down/Power before finally taking it apart. It looks like disconnecting/re-connecting the battery worked
by MichaelRomaniello
