Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149 Questions View all
iPod 6 gen makes weird colors and won't turn on properly
In April I had tripped on the beach as a wave crashed and it somewhat messed with my Ipod(I dried it in some rice almost right after). It wasn't until around August I realized it worked, but a few weeks later it mess up. I go to turn it on and it makes these weird colors and goes back to the apple logo. What do I do? How do I fix this?
Add a comment
1 Answer
You likely have salt water corrosion inside your iPod. You would need to open your iPod and clean any corrosion from the motherboard using alcohol (or even better, a professional ultrasonic cleaner) . Replacing the battery is usually a good idea after water damage too. That may be enough to fix it, or if not you will need to inspect the motherboard under a microscope to look for any damaged components.
Add a comment
Add your answer
aworriedcalifornian will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 2
Past 30 Days: 3
All Time: 52
