How do I replace Fog Light Assembly?
I need to know the easiest way to replace my passenger side fog light assembly.
I found this answer here:
These instructions are for a 2000 Pontiac Grand Am GT. I suspect the 1999 model is similar. Wear gloves and eye protection when handling halogen bulbs
Reach under the bumper and feel where the fog light electrical connector is located. You can stick your head under there to take a look if you need to do so.
Grab the connector (not the wires) and give it a counter-clockwise twist about 1/3 of a turn. This will allow you to pull the bulb out of the fog light assembly.
Lift up on the clip on the connector and remove the old bulb.
Insert the new bulb into the connector. Be sure not to touch the bulb. Clean the bulb with alcohol if you do touch it.
Carefully insert the bulb/connector assembly back into the fog light, and seal it with a clockwise twist.
I just performed this operation on my own vehicle. It was no problem at all.
Hope it works,
Frank
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 3,189
