Why can't I delete any media file from memory card?
If I want to delete from SD card it says I have no permission to. Or an error occurred
@busisiwe , Bus, check out the links below to see if they can help in deleting the media file on your Onetouch to get around the no permissions. Good luck.
Probably your SD card has got corrupt. Sometimes, an SD card behaves like a locked card, even if technically it is not. Then you need to remove the write-protection switch. You can visit this link if that is the case for further details: http://www.retrievephotos.com/article/fi...
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 5
All Time: 399
1 Comment
Can you please list the steps you are taking when you try to delete?
by Josh W
