Phone has no signal (SIM card works)
Hey all,
The Nexus 5 no longer gets a signal with the SIM card in. Tried the SIM in another phone, and it works fine. The IMEI is recognized on the phone, so I think it's a hardware issue. Is there a part I could replace to fix this? I'd prefer to keep this phone instead of ordering a new one.
Thanks!
edit: I should add, WiFi works fine, and it even says "No signal.|CITYFONE" in the pull down menu.
2 Comments
Hi,
Check in Settings > Wireless and networks > More > Network operators > Select Manually to see if it can detect other carriers. If so then the signal detect circuits seem to be working.
Have you tried another known working compatible network SIM card in your phone to see if it works, just to doubly prove that it is the phone that is the problem?
by jayeff
Tried using my wife's SIM in it, and it seemed like it had signal for a minute or so before reverting back to no signal. It's possible now that it isnt recognizing SIMs at all. Before it was, though, the Network Operators menu was populated with a few choices. Choosing any of them did would not connect the phone.
Thanks!
by Daniel Henry
