The March 2015 update of Apple's 13" MacBook Pro Retina Display, model A1502, features fifth-generation Intel Core i5 and i7 processors and introduces the Force Touch trackpad.
1186 Questions View all
Beer spill, battery & ssd shot
I dismantled & cleaned everything. There was sticky flow residue running from left side of logic board from vent down to battery. Slight greenish corrosion on keyboard backlight terminal, but otherwise looked in decent shape. None of the moisture damage indicators have turned red on the logic board, but the battery PCB is bright red & won't charge nor run from battery. She won't boot from the SSD, but will boot from an external drive. SSD gets immediately too hot to touch, and the fan runs at max velocity. Also, the fan won't run w/ SSD removed. My DIY dilemma is determining whether the PCIe circuit has been compromised. I don't want to install a replacement SSD if there's a possibility of frying another drive. Anyone able to test if fan starts at boot w/o SSD? Not an electronics guy & having brain pain from trying to decipher schematic. Lots of nearly microscopic stuff in there. Sheesh!
2 Comments
Thanks Reece. I was afraid to plug a new SSD in until I determined the logic board was ok. Now my only issue is the battery. She won't start from battery, and will immediately boot when magsafe connector is engaged. The light on the magsafe connector is first green, and, after a few seconds, turns to amber. The battery is recognized by the system & the menu bar icon indicates charging w/ 47% power. Battery condition is "Replace Now". I'm guessing the battery PCB is bad, or the whole battery assembly is shot, Are there ways to troubleshoot this & can this status be reset.
Thanks a million
by
Glad the SSD sorted it. The green>amber light on the charger is normal. The battery will need replacing, the PCB for this is attached to the battery itself.
Get a long, flat painting knife, and you can carefully slide it underneath, while dipping it in isopropyl to help loosen the tape. Be careful though, if the battery is punctured, it is dangerous.
If you haven't done this before, might be best to buy the whole palmrest with keyboard, battery and trackpad. Make sure you buy for 2015, batteries are different.
by
Add a comment
1 Answer
Chosen Solution
Sounds like the SSD is shorting to ground if it is getting hot. Very likely a new SSD will resolve this, haven't come across one before where the SSD was shorting, and it was a something on the logic board causing this.
On this model, the fan only spins if the MacBook thinks it's getting hot, it doesn't spin all the time like older models (yes, it's strange). The shorted SSD is setting off a sensor issue, since it is shorting to ground, which is why the fans run full speed. Again, a new SSD should sort this.
Not charging/running off battery will be because of the corrosion. Thoroughly check the board for any corrosion and clean it using a brush and isopropyl from the logic board and battery board (unplug battery from logic board whilst doing this). Chances are the battery is dead however, and needs to be replaced. Could be something else with the charging circuit on the logic board, but I would say it is the battery if this is where the corrosion is.
The 2013+ MacBook Air and Retina models use the same SSDs (although I think the 2015's have a slightly faster drive, but the older models will work in the 2015 model). If you know anyone with these models, ask if you could try the SSD inside to make sure before ordering it, since it is an expensive part.
Score 2
Add a comment
Add your answer
Mike B will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 221
