2.5 GHz dual-core Intel Core i5 processor (Turbo Boost up to 3.1 GHz) with 3 MB shared L3 cache.
265 Questions View all
MacBookPro 13" Retina beeping 3 times a1425
I bought a second hand macbook pro retina 13". It looks like great, but if i want to start, it is beeping 3 times. It was water damaged, but I try everithing. Pcb cleaner, heating, but just beep, beep, beep..
The dc-built in adapter was not damaged, just the mainboard water indicator what is red, and its charging
Can i change the ram modules, or reball?
Somebody met with this problem whit this mac?
Add a comment
1 Answer
Chosen Solution
With liquid damage, this is usually caused because there is some liquid under the RAM chips. Had a couple of Air's before which would beep when doing an NVRAM reset, resolved with an ultrasonic clean. Scrubbing the board will not help, take it to someone with a good ultrasonic cleaner, so it will submerge and clean under the chips.
It is possible to remove, reball and even replace the RAM chips with one from a donor board, but it is not fun, and you will need to know which one is causing the problem. If you have never done that before, I wouldn't recommend it.
Score 1
Add a comment
Add your answer
Balazs Szabo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 1,138
