How to fix the seventh generation of Honda's compact car.
72 Questions View all
Horn 'button' does not work
How do I replace/fix the steering wheel activator system for the horn?
Score 1
Add a comment
Chosen Solution
@leojik , Before pulling the steering wheel because your horn does not work, Check all fuses and horn relay and the horn itself. May be bad/corroded ground at the horn. Links below show horn fuse/relay locations, horn location and removal, steering wheel removal to access horns wiring/plug. Check the attached links,instruction and guides, Good luck.
http://troubleshootmyvehicle.com/honda/1...
https://www.youtube.com/watch?v=0ra0E0ph...
https://www.youtube.com/watch?v=d0GHgOCh...
Score 6
Add a comment
I have put a live feed to the horn and it works but no live feed at the steering wheel and the srs air bag light is on
Score 1
1 Comment:
Through research for my own car, it appears that your issue is to do with something called the "coil spring". It's a device that allows the wires for the airbag, horn and other wheel controls to turn with the wheel without being damaged. Here's a YouTube video for you to take a look at: https://www.youtube.com/watch?v=3vFkSuoz...
by
Add a comment
Add your answer
Leo Klump will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 95
All Time: 13,078
