Revamped version of the iPhone 3G with faster processing speeds. Repair of this device is similar to the 3G, and requires simple screwdrivers and prying tools. Model A1303 / 8, 16 or 32 GB capacity / black or white plastic back.
1502 Questions View all
Water, cleaned, new battery & dock. Works but not charge or sync.
3GS Toast after water damage. Completely cleaned. New battery and new dock connector. Phone works great but will not charge or sync. Looks like logic board is shot. I can't think of anything else to try.
Anyone repair logic boards if I have identified the exact broken capacitors (part??) ? I must have damaged the 2 small capacitors 1/4 inch to the left of the no. 4 pin connector (circle 8 blue lines surrounding capacitors just to left of fixation screw joint) per this hires photo of board. http://s1.guide-images.ifixit.com/igi/hs...
Any ideas or is board toast? prior post re this repair effort: dropped 3GS in toilet. Dried then cleaned. Battery low & not charging...
Prior post: dropped 3GS in toilet. Dried then cleaned. Battery low & not charging
Any ideas re having the logic board looked at????
Score 1
Add a comment
Chosen Solution
Try this answer No USB Connection after I broke little SMD element near connector #4!
Score 1
Add a comment
Nope, sadly there's not much you can do to fix the logic board once you've isolated it as faulty. :(
1 Comment:
Anyone repair logic boards if I have identified the exact broken capacitors (part??) ? I must have damaged the 2 small capacitors 1/4 inch to the left of the no. 4 pin connector (circle 8 blue lines surrounding capacitors) per this hires photo of board.
by
Add a comment
Add your answer
Victor will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 1,445
