Won't stay charged without the adapter
I bought a new battery but the notebook will not stay on without the plugin adapter.
I ❤️ love this little notebook I use it as a journal. Can u fix it?
Areulia from Chicago
albertroseaoj@yahoo.com
6 Comments
Hi, Does the new battery get fully charged?
by
Thanks forgetting back to me yes it fully charges but once it's unplugged the computer turns off. Let me know if I can send it in. Thanks
by
Hi,
Ifixit doesn't do repairs. The site only tries to help people to fix the problem themselves.
What was the problem that made you buy a new battery? Was it the same as what is happening now?
by
Ok thank you can you recommend a shop that will fix this notebook?
by
where do you live ?
we may have members in your area that can help
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
@areulia you can try this it may help with your problem . Remove the battery and disconnect the power cord . Then once everything is disconnected hold down the power button for 60 seconds . While you have the battery out check the connectors of the battery to make sure there clean then check the laptops connectors are clean as well. Sometimes batteries a shipped with covers on there connectors and if not removed it may not charge properly . Once you've done this , put the battery back in and plug in the laptop reboot and leave the laptop to charge for a while. When you get 100% on you status bar pull the plug and see if it will run off the battery.
Score 2
Add a comment
Add your answer
Areulia Shakir will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 139
