Android tablet released in January 2015. The Dell Venue 8 7840 has an 8.40 inch display with a resolution of 2560 pixels by 1600 pixels.
6 Questions View all
My tablet won't connect to the internet?
Whenever I try to connect my dell venue tablet to a WiFi network, it connects for a little bit then fails. I don't know what the problem seems to be.
Add a comment
Most Helpful Answer
Hi Donnelle,
This has happened to me before. Try closing all the apps, turning the wifi off in the settings and turning it back on again. If the problem persists check if your other devices are not having a similar issue because if they are then the problem is with the internet and not the tablet. Hope this helps.
Score 1
Add a comment
Hi @donnelle !
Can you tell us what operating system is in the device? I'm suspecting Win 10, but that's one thing we need to know. Also, what is the history on the device? Has it ever been dropped, wet, etc. Does this happen no matter which wifi you try to access or only on certain ones? What you're describing, sounds to me like a virus is potentially impacting your internet connectivity. Also, seeing your other two questions, I would suggest combining those and inserting the relevant device history.
Add a comment
Add your answer
Donnelle January will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 5
All Time: 943
