New display on iPhone 6 won't clip down on one side.
Replaced display on iPhone 6 but the new display won't snap down on one side. Don't know to fix it.
A picture might be helpful in knowing exactly what is going on. But there's a couple of things that may be the issue. If you have any dents on the corners of the frame, the screen will not be able to fit in properly. Also, if you have a cheap screen, the area next to the mute and volume buttons will not sit flush, as there is no clips on that part of the screen.
Put the top of the display in first. It kind of tucks under the frame, so gently push it towards the top. Then start working your way down the display, pressing down gently on both sides at the same time. If it still doesn't clip in, that means that you have something getting in the way. Its not uncommon to have a screw laying on the logic board or more commonly, you don't have the earpiece speaker lined up right.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 6
All Time: 203
