The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
299 Questions View all
After replacing digitizer, why does the screen power on and off?
I replaced a cracked digitizer, I used Kapton tape as instructed, and now I'm testing it to make sure it works before I stick it together. When I first pressed the power button it booted up with the white Apple against the black screen. Then it went to the wallpaper screen. Then it went black like it powered off.
I plugged it in, waited a couple minutes, then turned it on. It made it to the white Apple against the black screen, then it shut off again. If I unplug it, it won't power on at all. If I plug it in it will turn on just to the white Apple/black screen, but it won't get to the wallpaper screen again. It will turn on and off.
I tried resetting it by pressing the home button and power button at the same time, but it does nothing.
What do I need to check, or what did I miss or do wrong, or is this a sign of a faulty something or other?
Thank you for your help!
Add a comment
1 Answer
Chosen Solution
It seems to be acting as if the battery is not properly connected to the board. Did you unscrew the battery connector? If yes, may be you forgot to screw it back or tighten well.
I'd remove that screw, check for shards of glass, huff, puff, and blow the connector clean. Then put back the screw making sure that the battery prongs and the board prongs are properly aligned and making good contact. Don't overtighten and break anything though.
If that doesn't help, let us know to look for other issues.
Score 2
Add a comment
Add your answer
Susan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 106
