Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Replacing iPhone 6 home button ribbon cable (error 53)
Recently while replacing my iPhone 6 screen, I ripped the bottom connector of the home button ribbon cable at the bottom of the LCD heat shield. I proceeded to buy a replacement LCD shield with a built in ribbon cable, and installed it. It instantly went into an infinite loop of the apple boot logo and a flashing red screen. I immediately took it off and installed the original shield with the ripped connector and the phone went back to working fine minus the home button which obviously doesn't work. The phone is running iOS 10. I have a few questions:
1. Will updating the phone in this current state (with a disconnected/ripped home button cable) brick the phone with an error 53?
2. Will replacing the cable with a better quality ribbon cable or LCD shield make the phone work or will this result in an error 53?
3. If this does work, will updating the phone with the new cable/shield result in an error 53?
Add a comment
1 Answer
Chosen Solution
You'll be fine with any updating, error 53 has been removed by Apple and only ever applied to replacing the home button not the ribbon cable on the LCD shield. Boot loop and flashing red was likely caused by the new LCD shield being faulty and should just be a matter of getting a new one.
Score 3
Add a comment
Add your answer
Andrew Berend will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 4
Past 30 Days: 4
All Time: 134
