The fourth iteration of the popular 7" Galaxy Tab line of Samsung tablets.
136 Questions View all
Formatted internal storage, no boot AT ALL
I have recently wished to install a NORMAL GNU/Linux distro (Debian specifically) on my Android T230. I booted TWRP, opened the terminal and erased /dev/block/mmcblk0. I created a new MBR/Partition Table, and new partition, of type ext4. There, I pushed Debian files, using adb. I installed them on that partition. Then I set up GRUB (arm-uboot), and installed it in the MBR. I rebooted the system, but it did not boot normally, recovery nor odin mode. It does not even look to turn on (if you know the difference between the powered off screen and whole black screen, it's powered off).
I have some questions:
  1. Is there a way to do that. other than buying a new one?
  2. The warranty was void already. If I brought it to a Samsung service and paid a bit, would they accept it? Would they make it boot or factory reset it?
  3. Can I recover it by connecting it to a PC somehow?
  4. What is exactly happening?
  5. Was Odin Mode SERIOUSLY on internal memory card???
  6. What GRUB should I install if not arm-uboot? arm-efi?
  7. Can I recover the package files/stuff?
Add a comment
Chosen Solution
To be honest,
Your best bet is to ask your question on xda-developer.com
http://forum.xda-developers.com/tab-4/he...
As for getting a replacement, since your warranty is void, they might make you pay for an "out-of-warranty replacement", which will cost you.
Hope you can get your phone working again.
Score 2
3 Comments:
Thanks for the "out-of-warranty replacement", I meant precisely that.
I will ask on XDA, and possibly other advanced forums.
Thank you.
by
Glad to help out :)
by
Have you solved it? I am facing the same problem.
by
Add a comment
Ideally, you can reinstall the GRUB/GNU boot firmware from a simple file. If you want to install the bootloader, go to http://ftp.nl.debian.org/debian/dists/te... and click on the mini.iso file. I believe this is the bootloader file.
1 Comment:
Please note that you need a micro SD card for this.
by
Add a comment
Add your answer
Jakub Kaszycki will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 10
All Time: 213
