Stick brush head won't spin when vacuum is on.
Heading text
bold text
bold text
Hi,
Here are two links which may be of some help.
The one shows how to use the inbuilt Brushrollclean feature.
https://www.manualslib.com/manual/611389...
This one shows how to remove the brush roll from the cleaner so that you can check and see if there is anything caught in it, like threads etc., which may prevent it from rotating.
Light will not come on brush roller and it does not work
Same problem: motor and light would run temporarily for 3 - 5 seconds and then turn off. Replaced the small motor (Jameco Electronics part number 206949QJT-360S-14280 ) in the brush head and lubricated the pivots on each side of the roller brush. Not sure, but resistance against the roller brush may have damaged the original small brush head motor. Don’t use the vacuum brush head on throw rugs or other carpets.
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 42
All Time: 18,755
