machine drains, but when trying to spin makes a loud ratcheting noise
loud grinding /ratcheting noise when trying to spin after tub drains
DL, Sounds like a problem with the gear case/transmission. Check the attached links,instruction and guides, Good luck.
possibly the coupler? lifted machine looked at coupler. found a lot of black rubber "dust" around coupler.Your thoughts?
DL, yes, coupler could be worn/damaged/loose cheap fix if that is all it is. Change coupler if damaged and see how it goes. If noise returns transmission change. Good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 53
