Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
Phone shows in iTunes, makes no charging noise & screen is black?
I replaced my phone screen for the iPhone 6, did everything just fine (Ive installed many phone screens). I go to turn it on after letting it charge for a while before hand, and nothing happens. So I try a hard reset. Still nothing. I plug it into iTunes, screen is still black, but it shows up in iTunes? But, when I take it on and off the charger, no charging noise occurs whether on vibrate or the sound is on. It also doesn't make a noise when I flip the switch either way. I ordered a new screen again thinking it is the LCD, but I am really worried it is something else?
Add a comment
1 Answer
Chosen Solution
Keely, Found this info. from another post, possible no back light after screen replacement. In IPhone 6 can be caused by damage from mixing up the screws. Using longer screws where they are not to be installed.
Check the attached links,instruction and guides, Good luck.
https://www.youtube.com/watch?v=a_gqaj1-...
http://hackaday.com/2014/10/19/using-the...
Score 2
Add a comment
Add your answer
Keely Haggar will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 63
