Repair guides and information for Microsoft's Surface Pro line of 2-in-1 tablets.
574 Questions View all
hub usb (from china cheap) killer
Hi
after plugged an hub usb (from china cheap), initially first time to my surface pro it woed ok. Just powered off the pc and caming back after 3 hours. During my absence it was non charging but with usb hub plugged (The hub was connected by its trasformer to electricity home at 220 volt).
When i caming back home, I tried to power on notebook but it does not start aniway pressimg the start and/or volume button (as microsoft suggest.
I think thae hub (powered) destroyed my notebook. Can sombody give to me confirmation ? thanks . Regards
Add a comment
Chosen Solution
It is possible that there was a short in the USB hub and it blew something in the Surface. Try holding down the power button for a full minute, then the power and volume button for a full minute. If that doesn't get it to boot, then its almost certain that something fried internally.
Surfaces are great, I use one myself. But they are nearly impossible to repair on your own. I work on electronics every day and I wouldn't want to open mine up. Microsoft does offer repair on these and I've used their service before and was satisfied with it. If you elect to go that route, they send you a new one instead of yours. So be prepared to lose some data.
Score 1
4 Comments:
thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks thanks
by
thanks my friend, you saved my life
by
I want to be eternally gratefll to Josh W for its answer. It really turned on on life the surface after i gived it for died last 24 hours. Miracolous the contemporaney pressing buttons (powewer and volume) and it startup just one second, but important most was that charger white led revived. From this point the caming back to normal life was short (just the time to little charge).
Do you think that the hubusb chinese cheap was the cause of crash. I decide not to use animore. thanks a lot to josh, wish he can get this message. Gratesually fully this blog i discovered casually googling
by
Glad its back alive! I had mine do that once after a Windows update.
by
Add a comment
Add a comment
Add your answer
alfonso grillo will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 7
All Time: 267
