iMac Intel 27" EMC 2309 (Late 2009, Core 2 Duo 3.06 or 3.33 GHz) ID iMac10,1, EMC 2374 (Late 2009, Core i5 2.66 GHz or Core i7 2.8 GHz) ID iMac11,1
384 Questions View all
My fans are going full blast.
I just installed a new hard drive in my 2009 intel imac, and now the fans are blowing full blast, which is what I was afraid would happen because the new hard drive didn't have a port for the thermal sensor cord. How do I slow them down?? It's really loud.
Score 1
Add a comment
Chosen Solution
James - The best way to solve this is to install a replacement thermal sensor that is designed to work with your Mac system. Here's what I recommend: OWC In-line Digital Thermal Sensor for iMac 2009-2010 Hard Drive Upgrade it will supply the systems SMC services the needed thermal input to correctly manage the fans within your system. In addition you may want to get a better view of things this is what I recommend for that: TG Pro.
Score 1
Add a comment
The conecter that goes to the hard drive has a white dot on It. It needs to be facing up. It will connect two ways. If you install it wrong the fan will run fast and it will be noisy. You have to open it again and turn it over. There is a repair manual on ifixit.com. You need to know your EMC number. It is on the bottom of the stand. For instance mine was EMC 2308. It sounds like we the have same computer. I replaced my drive on an early 2009 21 1/2 desk top. Good luck. If you have any other question about down loads etc. post a comment.
Update (09/28/2016)
Here is a link for the repair guide you need . Tap on or click on the blue link. I think this should help.
iMac Intel 27" EMC 2309 and 2374 Hard Drive Replacement
Add a comment
Add your answer
James Singewald will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 78
