How can I fix my laptop have happy face & Question mark?
I have laptop Mac powerbook G3 lombard hard drive 4GB if i start up screen on and have happy face and question mark is mean have problem with hard drive? and i hear spinning, can i fix a hard drive or replace it .thank u
Add a comment
1 Answer
Chosen Solution
Probably a hard drive issue, usually that comes up when it doesn't know which drive to boot from so it might not be seated properly. Or, you might just need to select the drive if there are options appearing on that screen for you to choose from. If there is nothing to select and you feel comfortable with tinkering, I'd disconnect it from power, shut it down, and open it up. Check that all your RAM is properly seated and the hard drive is connected properly. Possibly some cable came out a bit if the device fell or was knocked around a bit. If none of that is an issue, or you don't feel comfortable checking it out, take it into a repair shop and have them check into it.
1 Comment:
i try put cd install on this powerbook g3 is work and now turn off maybe because need replace Pram Battery, without Pram battery that laptop can not on?
by
Add a comment
Add your answer
Linah will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 39
